Hey guys so I went to drop my skid plate the other day and 3 of my nutserts stripped off in the frame, so I had to cut the bolts off with a torch. Which ultimately lead to the bushings that go between the skid plate and the frame to catch on fire.
The problem is I cant find any replacement bushings anywhere. I called quadratec and they said "we wouldn't carry anything like that". I have a 3.75" suspension lift on it and I called Rough Country also and they said they never included those in the kit and couldn't help me out.
Does anywhere know where/what I need to get? Any help is appreciated!
Mostly old school..!
Sounds like someone installed a transfer case drop kit to deal with drive line vibes due to the lift. The stock set up is to bolt the skid directly to the frame. You can do a search online for transfer case drop kit and probably come up with some spacers, or if they are not very thick, stack some washers.
Get a hold of XTRyan, one of the vendors here: http://search.extremeterrain.com/se...e+lowering+kit&vwcatalog=yhst-134676801646993
Ahh I bet thats what it is! Thats weird though because the drop kit was already installed when I bought the jeep but I put the lift kit on...weird.
I would get a MML and hopefully you can lose the TC drop. Or at least eliminate the tc drop to a couple washers
