Where is the vacume switch located on the transfer of a 1993 wrangler with the 4.0 and 5 speed ??? Drivers side or pass side and is it to the front of the transfer or rear ?? Is it easier to get to it with the shifting cover off of the floor boards to replace ??? As you might have guessed I didn't look at it yet or crawl under to see where it is !!! Just thought I might get some input here !!! Thanks in advance ...Jerry
Well ifit is the vacuum to the cad system to lock in the front axle it is actually on the transfer case you can't miss it top rear center.
If it is to an auto trans no idea.
