A few years back, I broke off one of the bolts in the frame on the transmission skid plate when installing my lift.
I was so mad at myself for basically not paying enough attention to how much power I was using, and the bolt broke deep in the nutsert. I messed with it for a while before finally deciding to move on.
To get to the point, imagine how excited I was when I bought a warn oil pan skid plate and found that not only was I going to remove that trans skid plate and not have any use for it, but that it did not use either of the two forward most nutserts. After months of beating myself up over it, it turned out to be of absolutely no consequence.
My suggestion, save the torches and the welder. If they are spinning, there is probably enough room to get a sawzall blade in there. Cut em off and replace that skid with protection that you are going to need anyway in the form of an oil pan skid plate. The Warn that I suggested is not the toughest one you can buy for sure, but the price is reasonable for the added protection you will get for light to moderate off road use. And it's design totally solves your problem. It worked for me.
