Last summer I had a leak from what I thought was my transmission pan. I took it off and did see a few spots where the cork gasket looked like it was burned away. I replaced it with the Lubelocker gasket. Still had the same leak. I re-torqued all the bolts. It's still leaking. It leaks when the Jeep is sitting.
I wonder if it's not the pan. It looks like it's coming from above the pan. I checked the transmission lines and they seemed ok. I REALLY hope it's not that line towards the rear cuz that's a bear to reach. I felt all around under the lines and didn't feel any leaks. Could it be from a sensor or another place, or the pan still?
Thanks
Art
Nope but it did stop leaking for now. I wonder if overfilling would leak in that area because the level is right where it should be now
