JK 2008 X-limited having problems with the stransmission changing to second gear..!! In the morning works fine for about 5 minutes ( changes gear normal).
on the highway it falls in gear 1 and stays that way! Panel lights PNDR1 lit up.
any ideas ?
cheers,
Marc
The first thing to do is check your trans. fluid level, at operating temperature, in park. The fluid should be a pink/red color. If not there could be some issues. I have no idea what you're showing regarding the connecter. If it has to do with the trans. electronics that would be a problem. At this point you probably need a trans. shop.
Kik, thanks for your quick reply... this is the connector on the transmission that is loose when playing with this the car does not start. or after playing with this it works normal for 5 minutes....then looks like a glitch and loses it again.
