Hello all,
I have a 2014 Unlimited Sport (2.5in suspension lift, 35inch tires, 20inch wheels, aftermarket bumpers, and side armor). I've had the Jeep for 2 months. It had 54K miles when I purchased it. Yesterday, during my ride to work, I noticed the transmission would not shift from 1st gear to 2nd gear. Additionally, there was a delay in acceleration after I moved from a stopped position (my RPM spiked first followed by movement). My check engine light then illuminated about 2 miles after I noticed these issues, and as I was parking for work. I parked the Jeep, and 8 hours later, began the ride home. Instantly the Jeep would not shift into 2nd gear. After about 30mins of trying to drive to the nearest dealership (traffic was bad per the usual), the transmission went into limp mode. The OBD II read U0414 (Lost Communication with Four-Wheel Drive Clutch Control Module). I'm thinking this is symptom of the check engine light, however I don't know what caused the gear shift issue. Has anyone experienced this problem. If so, how did you resolve it. I have 61K miles on the vehicle, and the powertrain is under factory warranty. It's currently at the dealership for service, but I'd still like insight from fellow Jeepers. I didn't find anything on the TSB, and I've only found general descriptions related to the code. There was no fluid transmission fluid leakage fyi.
