Hello All!
Im new to the site and I like it very much. So I have a dilemma.
04 TJ Automatic 4.0l.
Dragging noise coming from transmission/ transfer case are. It gets louder with higher mph. I pulled front and rear shafts to verify location of the noise. I had the noise also with engine off and transmission is neutral.
The noise originally started from the left front wheel it seemed and after replacing hubs and even getting to the point of removing the front axles and using stub shafts in the hub...and puling out the front drive shaft..4wd is no longer on option at this time.
My question is, to verify the transfer case, would I be able to put it in neutral and still have drive capabilty? I have a chain noise coming from the transfer case as well.
Thanks and Happy New Year!
actually, what i meant really, was, if i put the transfer case in neutral and put the transmission in gear would I be able to engage the transmission to spin...knowing i wont go anywhere.. but see if the noise is in the transfer case or the transmisison?
