I'm looking at a 1980 CJ-7 with an AMC 360/T176/Dana300. The transmission slips out of gear quite a bit, especially when applying power. I was told that the synchros are bad. First, is that true? And second, how involved (expensive) is that to fix? I've never touched the inside of a transmission, and I really don't feel comfortable tearing into one without help. Plus, my tool selection is limited to basic stuff and body work tools.
Also, the seller put on a brand new Holley carb, but never adjusted it...just stuck it on the intake and hooked it up. It starts easily, but there's a huge dead spot just off-idle and it acts like a Harley...it won't stay running unless you constantly rev it up. (Just messing with you Harley guys.)
Lastly, the throttle pedal is stiff as HELL. Is there a trick to making that a little more user-friendly?
Thanks in advance for any of your help.
:D
:D
Not a mechanic here, but I'm gonna put a Howell throttle body injection unit on my '80 CJ V8. They ain't cheap, but they are supposed to beat the hell out of a carburetor. (I've run both a stock and a Holley carb). One guy on this board says the Howell unit keeps the engine running even when the Jeep is upside down; no carb will do that!
I really just want to get it running smoothly for now. Eventually I want to yank the AMC 360 and replace it with an injected Ford small block.
