My jeep feels like it is slipping 2nd gear. When going in a straight line from a stand still or when slowed down and trans shifts down to 2nd it feels like it is slipping before it fully engages in the gear. The only time it doesn't do it is if I'm turning from a stand still. Then it shifts as should but it runs the rpms in 1st fear up to about 26-2800 before shifting. It basically happens anytime the trans shifts and rpms are under 2500. I took it to the dealer and they have reprogrammed with updates twice now to no avail. It was doing it with stock tires also. I have since lifted and regeared to 4.10. Since regearing it isn't quite as bad, but its still doing it. Its like it doesn't have the right line pressure to make the shift happen. Maybe a torque converter issue?
I'm also holding 3rd gear way to long, even on the slightest inclines. I will go to 4,000rpms and never shift. I have to completely let off the gas before it will shift.
I'm about to take it back to the dealer for the 4th time with this issue. Yes my local dealer sucks bad. Any advice anyone can give me? Is there a tsb that I haven't been ae to find through my searches? Jeep has 27k on it. Any wisdom is greatly appreciated.
