i need some help i have a 1999 2.5 4 cyl jeep wrangler standard transmission. when going down freeway it seems the trans is slipping. it doesnt do it when i start from a stop just at higher speeds is it the trans or could it b something else thanks for your help
Yea and more the hotter it gets... Sounds like a weak pressure plate which is part of the clutch assemble and holds the clutch up aginst the flywheel... Hotter it get the weaker it is so more slipping.... New clutch is less than $150.00
