1 - 13 of 13 Posts
Thinking about trimming my stock fender flares, wondering if anyone has any tips or tricks for this project? Thanks in advance
Get a sharp blade, score where you want to cut the fender. You could do it a couple times gradually getting deeper, then you literally peel the excess fender off.
Works like a charm.
got any before after pics? is it just the side flare , or downward part of that side flare that you are trimming? I see some pics of people saying before and after, but usually to far away for me to notice exactly what was trimmed.
take a photo before you cut, and take another one after you cut.
Thanks! :flipoff:
I knew I would get a good smart-a$$ reply from that, regardless of my edit note... lol!
I was wondering if anyone has some close up pics of this so I can figure out how far up to go with my cuts? And I was planning on a chalk line were I want my cuts then scoring with a razor knife, sound about right? Also if you have done this did you also trim the small part that runs parallel with the bottom of your rig? I wasn't sure how that would look?
The first 4 pics are after. Don't mind the spots on fenders :p haha messed that up but did fine in cutting. The last two are old pics of the jeep the summer I got it
I cut 1 inch off the front and 3/4 inch off the rear. I think I'm going to trim rear more though.
Hope this helps
Discussion Starter · #11 ·
Hey guys sorry about not posting, had a emergency come up on the weekend I was going to work on this project, and since then between inlaws being in town, work, and general holiday hustle and bustle haven't even started yet! Hopeful I'll get to it this week but also have a new cb to install and a trip to the mountains at the end of the week. If I don't get to it this week I should have some time next week and will post before and after pics with a write up!
@cjs98tj thanks for the pics I think I'm going to try and trim a little more off of mine to make the almost flat
I trimed mine with a razor knife. Just measure and tape so you have good lines. score it and then cut deeper. save my pic and then you can zoom up on it
If there are small mistakes don't worry about it I just used a file and sanded it down. Then I torched so they are smooth
1 - 13 of 13 Posts
