TJ friends,
my TJ (97) is having trouble starting after a short drive, ie. on a hot engine. It will start after parking overnight but after a short drive and after engine cut, it will sputter but just won't start. It seems to have enough energy, so we can rule out the starter and battery.
Has any of you had this problem? I could use some help on where to begin to diagnose. Is it a fuel or air issue? Can I get a code read when the engine light is not on?
'08 Rubi / '98 TJ / '05 Tacoma
x2..does sound like Vapor lock. Definitely worth a shot since it's an easy fix.There is a TSB on it:
and here is the tsb:
Fuel System - Hot Start Misfire/MIL ON/DTC's/Rough Idle
NUMBER: 18-031-03
GROUP: Vehicle Performance
DATE: Sep. 05, 2003
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 18-027-02, DATED SEPTEMBER 06, 2002, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A COMPLETE REVISION AND NO ********S HAVE BEEN USED TO HIGHLIGHT REVISIONS.
SUBJECT:
4.0L Rough Engine Idle After Restart Following A Hot Soak
OVERVIEW:
This bulletin involves the installation of a fuel injector insulator sleeve.
MODELS:
2000-2004 (TJ) Wrangler (Domestic and International Markets)
1999-2004 (WJ) Grand Cherokee (Domestic and International Markets)
2001-2004 (WG) Grand Cherokee (International Market)
2000-2001 (XJ) Jeep Cherokee (Domestic and International Markets)
NOTE: This bulletin applies to vehicles equipped with a 4.0L engine (sales code = ERH)
SYMPTOM/CONDITION:
Customers may describe a 20 to 30 second rough idle following the restart of a heat soaked engine. This condition may be most noticeable when the engine is restarted following a prior 10 to 20 minute heat soak in hot ambient conditions of approximately 32°C (90°F) or higher. This condition may be consistent with short city stop-and-go driving trips and can be aggravated by the use of fuel with a high ethanol content. Depending upon various conditions a MIL may occur due to DTC P0303 - Cylinder # 3 Misfire.
This condition may be caused by heat from the exhaust manifold that following engine shut down migrates to the area around injector # 3 and causes fuel vapor to form within the injector. This in turn may cause a momentary misfire of cylinder # 3 until the fuel vapor is cleared of injector # 3. The insulator sleeve lowers the injector # 3 temperature to a point below which the fuel will not normally vaporize.
DIAGNOSIS:
1. If vehicle exhibits a rough idle, and if a misfire of cylinder # 3 is observed following a 10 to 20 minute hot soak, perform the Repair Procedure.
PARTS REQUIRED
REPAIR PROCEDURE:
1. Cut insulator sleeve, p/n 56028371AA, to make two (2) insulator sleeves about 25-30 mm (1 in.) in length.
2. Install one sleeve around injector # 3, with the slit on the upward facing side of the injector. Install the other sleeve with the slit on the downward facing side of the injector.
3. Confirm sleeve is flush to intake manifold surface around injector.
4. Check injector # 3 wire and ensure that the injector is rotated to a 2 o'clock position (from driver's side of vehicle).
