so its starting to get cold out here in mississippi and i have an issue when starting cold, i turn the key nothing no turning over sound no cranking nothing, i turn key off then back on and bam it starts with very little hesitation, im thinking maybe the battery.?.
I'm going to guess....
I would clean all of your connections related to your starting system and battery posts. Don't just look. Take them off and clean them with a wire brush and/or post cleaner brush. Then cover them with dielectric grease. I personally use mineral oil.
C.
Show Me Your 8008135!
Do you get any lights on the dash, radio turn on, etc...or NOTHING...like completely dead? If that's the case, definitely check your connections. Also may check your starter relay if you're getting lights and stuff?
Check the connection at your starter. Disconnect and clean it up and as other have suggested, clean all other connections. Sounds like an intermitten connection with your starter. Hope this helps
