Im in the process of putting my Jeep back together and only need a few parts to finish it up this week.
The exhaust hanger above the muffler heat shield is rotted off.
It bolts to the body on a small channel of steel with two carriage bolts.
No one lists them as a replacement part.
Does anyone have an extra or know of an easy replacement without welding?
Going to be hanging a Dynomax exhaust this week.
Thats a good link, but no dice.
I tried a couple guys on Craigslist, same deal, its rotted to pieces.
Looks like Im gonna need to fab something up.
I have the same problem. I picked up a pair from my local shop. They are the right pieces but the Knuckle head who did the exhaust bunged up the job so now i need to either have the exhaust redone or fab a new hanger. grrrrrr I need an extra 3" to make the hanger meet the exhaust.
Wrenched one off a old Jeep at a junk yard for about $10. There were a lot of old Jeeps there and found one that wasn't bent all to hell.
Discussion Starter #6
I found a way around it.
If you trim the heat shield or notch it, u can use a 5/16" bolt thru the body mount where the mount was. And reuse one of the oem rubber mounts. Works perfect.
