I posted this on JF but didn't get a solution.
I've been working on this 3 days too long. Trying to remove the ac clutch to replace a dry bearing on the ac pulley. The fan, shroud, and rad are out.
I've removed the center bolt, per the fsm it's supposed to slide right off. I've talked nice to it, pryed, tapped, soaked with pb, heated, beat, pryed more, beat more, and cursed it more than a sailor.... it's a lot uglier but hasn't budged a bit.*
Any suggestions?
before the suggestions start.... I have Zero interest in removing and/or replacing the entire compressor because someone found it for $x.
The compressor I have is a 10pa17e. There are no pullers made for this clutch, because it supposed to slide right off.
At this point I'll probably have to replace the clutch and pulley because it's beat up pretty good if I can get it apart.
Any suggestions?
