The half console will give you as much if not more room. All it leaves is the original front 'cover' that pops right off after you remove the transfer case shift knob and then goes back on after the install. The rest of the console becomes the steel safe with the 'leather' padding. You also get an area in/under the front where you can mount switches on a removable steel plate that I don't think the full console has. It has the same electronics mounting option, which I chose to leave out for more room.
Happy Trails,
Bob
Thanks, the only thing about the half console is that its not the full console, which is what I want.
