So I got my security deck installed... now how about a liner. I didn't buy Tuffy's for $70, figured I could do it on my own. Stopped at Lowes and Home Depot to see what they had and figured I'd ask what you found working the best. And how did you secure the liner to the trunk so it doesn't blow away? Any water issues as far as being trapped under the liner and not drying out?
Many thanks, Rich
Could it be I'm over thinking... or has no one done this?
I bought some rubber/foam matting that looks like the metal diamond plates from one of the local discount stores and attached it with spray adhesive. Then added 4 D-rings from Home Depot by drilling holes and fastening with bolts.
I have a Canvasback liner (for the dogs) and it comes with velcro strips, one side with adhesive back that I stuck to the Tuffy deck
i bought some rubber/foam matting that looks like the metal diamond plates from one of the local discount stores and attached it with spray adhesive. Then added 4 d-rings from home depot by drilling holes and fastening with bolts.
x2
I used Tuffy anchors but the foam mat was from Home Depot.
Perfect, many thanks! I have the Tuffy tie down bracket and will use that for the sides. A quick stop at Home Depot for the d rings for back to front and that and I'll be done.
Thank you!
