hi my friend, last year I tryed to build an offroad-only jeep's...staying with the stock 4.0l engine but with a turbocharger. At my first try, (1999 4.0l with 180 miles) I just put a checkvalve before the map sensor and running at 8psi aaannnd 2 hour later a connecting rod was threw outside the engine block lol. after that I've swapped it for a 4.0l (2000 distributorless with 108 miles on it) with a new turbo setup at 8psi again (36lbs injector, liquid to air intercooler, split second ftc1-201 fuel/timming controller running on 8psi 34 lbs injector base map) after 1 week its worked fine, good compression (135- 145psi on each cyl.) but after 2 months a grey smoke started to comming out and alot of blow-by.... the compression was +/- 50-80 psi on all 6cyl.
What can cause that? till something I miss when I build it?
i'm new to that but I knew even if I running 36lbs injector with a 34lbs injector map its better to run rich than lean... the engine did'nt really run hot untill 2-3 time at 240f for a few minutes in a mud hole. Now i'm not sure if I go with a fully forged internal or a ls swap...
waiting for reply
waiting for reply
