I have an '06 Wrangler. The left turn signal has suddenly begun blinking very quickly when I turn it on. It looks like there is a left turn signal on the front of the jeep but no left turn signal in the rear. Also, the rear brake light on the left side does not go on. But it's not the bulb, since the bulb goes on when I turn the lights on. Any help would be appreciated.
the light might not be a ground. make sure all the bolts are tightened on the rear taillight. I had the same issue trying to put rear taillight gaurds on
Its the rear tail light bulb. It has 2 filaments. The brake / blinker filament is burnt. The running light filament in the bulb is good. Change the bulb
