I am noticing at night when I turn on my right turn blinker my dashboard lights go from the dim setting I have set at to all the way bright. Once the turn signal disengages it goes back to dim. Has anyone else experience this? It’s strange.
More than likely your MF headlight switch is going bad. You can get one off of eBay for around $50. A few torx screws and a phillips head screw and it's done. My 09 and my friend's 12 started doing similar things.
Thanks. That's what I thought it could be but wanted to see if it was common issue or not. I am under warranty so I think I will have the dealership deal with it.:lmao: My window lock is also not working so I may as well have them replace that too. :thumb:
WF approved Offical Jeep Account.
Hi AZweddo,
We are sorry to hear that you are experiencing this. If you would like any additional assistance while your Jeep is at the dealership, please send our team a private message!
Alex
Jeep Social Care Specialist
Mine was doing wonky things like signal a left turn and the dash goes full bright or does the same thing when I turned on the fog lights and the dash dimmer would not work.
Did the MF switch fix your problem? My 2014 is doing the same thing. And it is just the right blinker. I found on a couple other forums of people having this issue, but none of them fixed the issue.
Discussion Starter #7
I obviously forgot to update this. Not cool. :(
It did fix my issue. Had it replaced in January and haven't had the issue since.
