Any suggestions of where to start. Neither turn signal works.Emergency signal working perfect, side markers on with parking and head lights. Bulbs I think are all good! I have read it could be the ground! Would that be the ground for the entire jeep?
When working the turn signals there is a flasher just like the one for the flashers should be right next to each other. Since the flashers are working we know the bulbs are good and the wiring is good so get up on the fuse panel and locate the flasher when it is working you can hear it and change it out with the trun signal flasher. See if that is the problem.
