This is listed as the equipment in my jeep. Is this an open diff? Is it normal to have trac loc in rear only (no mention for front axle)
  • Command-Trac Part Time 4WD System
  • Dana 30/186MM Front Axle
  • 3.07 Rear Axle Ratio
  • Dana M35/194MM Rear Axle
  • Trac-Lok Differential Rear Axle
Mostly old school..!
You have a dana 35 rear axle with limited slip and 3.07 gears. You have a dana 30 open front axle.
Was the front limited slip an option for that year (2001 TJ Sport). The option list from the website referencing the VIN number does not mention trac lok for the front.
I am first time owner of a 2003 TJ. Same spec as yours. 130k miles and rebuilding rear TracLoc soon in rear carrier as it left me in a ditch.
I am still learnin about open differential in front. When in snow with traction in 4low 2 wheels pull. When in ditch only one pulls. This makes me think it has a worn out TruLoc in front. Anyone have thoughts on my open front differ tial why it behaves like this? I will raise wheels off ground and due the spin test this week to see if it might have True Loc in front.
To my knowledge, TJ's never came equipped with a front limited slip.
The only exception to that is the Rubicon models - when the lockers are not engaged I believe the diffs act like helical type LSDs.
It is an open dif in the front. Open difs provide the same traction to both wheels that is required to turn the wheel with the least traction. So if one wheel is in the air, there is the same force (as it takes to keep the one in the air turning) being applied to the opposite one.
Good information Water Dog. I will rebuild rear carrier then put it to the test before I decide to invest in front carrier. Thanks going to replace fender fares now and now spend time doing the spin test.
There was never a factory LSD for the front axle in a TJ.
Even on the Rubicon, only the rear diff is LSD.
