UPDATE:
I wouldn’t recommend what I did to troubleshoot and try to get this thing to come back to life, but I did want to share what finally worked. So that being said DO THIS AT YOUR OWN RISK!!! In the end what I did was prepare a USB drive with the most recent update. Then I pulled the fuse (F97) that controls the head unit. Plugged in the USB stick and started the Jeep. With it running, I plugged the fuse back in (yes I know the risk I took in possibly letting the magic smoke out and frying all kinds of things). The head unit then tried to update, but this time it looked like it failed off the stick and not OTA. It rebooted back into a useable radio, said it failed the update with Error 20 and to contact my dealer. This error however was a pop up, clicked ok and my radio was working again on the original version.
2 hours later, the head unit again asked to install the update via OTA. I made sure I had a clear sky above me and let it attempt the update. 40 minutes later, update installed fine and i verified that the new version is now installed And everything is working fine.
It‘s easy for me to just chalk this up to “it’s a jeep thing”, but it’s not. This is a UConnect problem and they need to provide a way to disable updates OR own up to problems like this and make things right for those that have had to spend in some cases over a grand out of pocket to get it resolved. I got lucky… this time…
