Hey guys, I recently got the interior lineX'd (so great), and I've been wondering if it's okay to just hose off under the seat. Are those connectors (for the airbag and seat heaters) water resistant? Obviously I won't be submerging them, but water on them shouldn't bother them right? I think I see a small o ring in the connector, and just to be sure I put a bit of dialectic grease all up in them. Just wondering! Thanks!
They 'should' be fine, the entire interior is waterproof. Its not like you're fully submerging the connectors. I don't have seat heaters, but I still have a bunch of wires. After I flooded the entire driver side in about a foot of water a month ago, everything has been fine.
Waterproof connecters are pretty easy to spot. They are sealed with a rubber material (gasket) at the connection and around where the wires enter the back of the connecter. If you don't see that they are not. You could always unplug, add di-eletric grease and replug. That will keep the water out.
