Greetings all. Purchased my first Wrangler a month or so ago. Always been a GM guy; 2014 Silverado w/ 9" lift, 2008 Z71 Suburban w/ 7.5", Tahoes and Escalades dropped 5 inches, etc. Decided to go the Wrangler route due to my work moving me to a location where a Wrangler is ideal.
I am a big proponent of doing things right the first time, paying more up front than in the long run fixing cheap stuff, etc. Which brings me to where I am now. I am super bummed with the driveability of my TeraFlex 2.5 Budget Boost lift. This JK is a pavement princess, and always will be, so I wanted to get enough lift to fit 35s, and be decent while driving. I was considering much more complete and expensive kits, but after reading a giant 20+ page thread (can't remember if on here or elsewhere) about the 2.5 TF BB being the best complete starter kit to fit 35s, I pulled the trigger. Nearly every post on there said it was, bolt, 35s and ride. People were saying it drove like a dream with all stock parts and the kit, including the stock track bar and suspension components, and no other supporting mods were needed.
Kit is installed, and this thing is terrifying to drive at highway speeds. Even at 45-50, it floats all over the place. At highway speeds, I am gripping (not holding) the steering wheel. Forget about steering with you knee for a split second while you plug your phone charger cord in, it immediately starts to go off course if not firmly or death-gripping the wheel. This can't be normal and 'driving like a dream' like many stated, so I am looking for your help is getting this thing where it needs to be.
>2014 JKU, Sahara. 41K miles. One previous owner, never offroaded. Drove straight and true when 100% stock.
>TeraFlex 2.5" Budget Boost, with shock extenders.
>35x12.50x18 Toyo Trail Grappler M/T. My choice tire, run this on nearly every lifted vehicle I've done, which is 10+. Tires and Moto Metals balanced well.
>Installed by a professional tech, who has done many Wrangler and other vehicle lifts
>I lowered air pressure on the tires to give them some more flex over variations in the road, which helped marginally, but the issue is still there.
>All bolts are parts are installed and torqued correctly. No play in components on the ground or on a lift in the air.
Alignment was done on a very modern rack. Numbers are even and good, nearly everything in the green. Caster is in the red, but nearly identical on bot sides; 2.9 and 3.1. Doing additional research, it seems like caster can a factor in the JKs wandering and floating all over the road.
Any other suggestions gentlemen? Reason I started with the rant above about doing things right the first time, is I would have gladly bought a more expensive kit that has caster adjustment parts in it, a track bar if that is recommended, and whatever else if dozens of posts hadn't said the BB as good as or better than stock out the box. Any input on what I need to add to make this thing safe to drive is much appreciated!
