1 - 20 of 23 Posts
I seem to be missing some parts from my jeep. I am trying to figure out what the part that screws into the top of the tail gate on both sides is. I seem to be missing the part on both sides an my interior gets wet every time it rains. When my hardtop back glass is closed you can see into my jeep around the rubber flaps:confused: . Any idea?
If you are seeing space between the glass and the rubber, loosen up the six bolts, now start at the rear, push the hard top in as far as it will go, and tighten that corner. Repeat on the other corner. Now tighten the other four up.
Retired Moderator
Hank, the hard top on my TJ has the rubber seal on the lower outside of the window.
and inside of the window, against the seal, is a hard plastic strip that seems to be formed to fit tight against the tailgate.
There isn't anything on the tub, itself, or the tailgate.
Do you have the hard plastic strip? If your top is all of the way on and you have the rubber, you may be missing the plastic strip.
(Sorry about the size of the pictures, things are still a little wonky after the new hard drive install.)
why dont you take a pic of the hole where you can see into your jeep that will be easier to figure out what your missing
duck tape always works good too haha
Your soft top should have this seal on it to keep the water out.
On the end of that seal is an insert that seats inside this piece on the tub.
Where can I find the seal in that picture? Its the rubber seal that attaches to the softtop rear window retaining bar. Mine no longer stays in place.
1 - 20 of 23 Posts
