I have found a number of new Wrangler owners doing "take-offs" with their wheels/tires and am interested to use on my TJ SE. I found a set of 17" rims (4 aluminum and 1 steel/spare) with very low mileage 245-75-R17 Bridgestone Duelers. Can run these using adapters from my 5X4.5 pattern to the 2020 Wrangler's 5X5 pattern?
My current tires/wheels are P225-75-R15) or 28.29" diameter and 8.9" width Proposed tires/wheels 245-75-R17 or 31.47" diameter and 9.65" width
Thanks!!
Retired Moderator
:welcome: to the Forum..:wavey:
Thanks!!
I have been running spacers for a few years. I had only one issue (right after I bought the jeep) in which my hub bolts worked loose and broke a couple of bolts. This was caused entirely by me not torquing properly and not re-applying lock tite.
Wheel adapters are not a place to pinch pennies. I would suggest using a known and trusted brand and make sure that they are a hub-centric design (many on Amazon and Ebay claim to be hub-centric but are in fact lug-centric).
Quality adapters installed properly work great. I checked torque after the first 500 miles or so and every few thousand thereafter and have had zero issues... even up to 95mph (on a closed course, of course ). Just follow the instructions carefully make damn sure you use thread lock!
Sent from my SM-G975U using Tapatalk
What's the question? Those tires are too tall for anything except street use, unless you lift it a little. I've used wheel adapters on several of my Jeeps with 35" tires. Don't be fooled into thinking you need the expensive adapters like Spidertrax. It's the stud strength that matters. I torque mine down and then use a dab of silicone seal on the threads. You never need to check them again because they can't come loose until you want them too. I paid $68 for all 4 of mine from Titanwheelacc on ebay.
Brand New Billet Aluminum Wheel Spacers / Adapters
- T6061 Billet / CNC Machined
- Comes with everything needed to install spacers onto vehicle
- These are designed to push the wheels out 1.5" from your stock settings
- Mainly used to give your vehicle an aggressive stance, and will help with any clearance issues (if present)
- Comes with 10.9 grade pressed in wheel studs and open ended lugs that have a 1/2"x20 pitch
p.s. I took a direct hit by a car to my rear tire at 50 mph and the spacer held up great. Broke the axle, driveshaft, control arms and lots of other stuff though.
This is great info. I was not aware of hub-centric vs. lug-centric. I use thread lock (removable version) all the time to secure firearm accessories. Makes even more sense to use it here.
Thanks!
Thanks for the info. No serious off-road planned until I do a modest lift. Do the instruction supply the amount to torque them?
My jeep cries a little every time it passes another tj w jk or jl wheels....
