YJ (1986) back from paint. After reinstalling the windshield washer nozzles (check your work as you go) the passenger side does not squirt and there is a trickle of fluid running down the inside of the firewall. It appears that the factory installs the windshield washer hose before the heater plenum. Another term for the upper heater plenum might be the cowl drain. I have dropped the steering column and have the dash hanging. I have also loosened the ECU bracket and set it aside. Does anyone know how to remove the upper heater plenum for access to the w/s washer hose? Lovely wife is pointing to part in question.
Thanks in advance, L.M.
She does look lovely! She kinda has that Vana White thing going on...
