Guessing manual? Since you said put it in first and not in drive?
Any forward gears work in 2wd?jcol said:Manual 4.0
Thinking the T-case Lando?Any forward gears work in 2wd?
Does 2nd work in 2wd? Without knowing any more info, I would say that your transfer case (NP231) might be the culpritGoes into gear I let out on the clutch n it just grinds extremely loud n fast in 2 wheel drive going forward in 2wd
Probably too much weight and torque put on from the board.jcol said:Well my rear end is shot. Dana 35 garbage. Literally just got this rear end a year n 3 months ago with very minimal off roading. $1700 down the drain
There wasn't a loud pop or anything? Sorry to hear about your bad luck. Time for a 8.8.jcol said:Well my rear end is shot. Dana 35 garbage. Literally just got this rear end a year n 3 months ago with very minimal off roading. $1700 down the drain
