I am planning a v8 swap in my '91 YJ, has anyone used the Advanced Adapter kit? How does it compare to Novack parts/kit?
Which V8 are you going with?
I'd like to know if there is a difference too. I'm doing a V8 swap in my CJ. I know advanced is a little less expensive.
I would suggest you look over the kits closely. "Low balling" an engine conversion is not the way I would go, if I was you. Look at the motor mounts. Look at how everything is engineered. You would be surprised at the differences. Check it out closely and then decide.
Take care,
