I installed a vacuum gauge this week to fill a hole I cut for a previous project and to help with my driving style / gas milage.
Looking at my readings, do I have a leak? I took the picture at idle when warm. Usually I am seeing 16-17 at idle and the needle is quivering.
Thoughts?
Knows a couple things...
It's normal for the vacuum to quiver a bit since there are 4-6 cylinders creating it. Vacuum is at its highest at idle and decreases dramatically under acceleration.
Maybe I am wrong, but I was under the impression that a good vacuum reading for sea level would be closer to 20 hg. (I hope I'm wrong!)
Your vacuum is likely fine but if you want, you can buy a can of throttle body cleaner and spray all the vacuum lines and connections see if the engine rpms change/stumble at any of the points you sprayed which would indicate a leak.
Thank you
