Hey
Finally found a aluminum valve cover for my 90 yj. I know rubber gaskets are the norm now days. I have found a felpro cork on eBay new. What do you? Cork or rubber?
Kind regards
M. David (GaTnMason)
Sent using Tapatalk
1990 Soft Top
YJ Wrangler 2.5L 4cyl.
31” tires back space 4” for wider base. 220,00 miles
If you can find a Fel-Pro blue rubber gasket to fit your valve cover, I suggest you use it.
I'm using a modified aluminum cover from a CJ 4.2 and haven't found a blue rubber Fel-Pro gasket to fit it. I've had to fiddle with the cork gasket to stop any seepage on the drivers side of the cover.
Finding a blue rubber Fel-Pro gasket for a 2.5 may be easier.
Good Luck, L.M.
Reactions: mdgilbreath
Yes I have found them as
well.
The cork is recommended for the aluminum valve covers
The valve cover is from a
1992 YJ 2.5
A gasket for a 91- 98 YJ or a Dodge Dakota 1998 will fit.
#50502R felpro -
blue rubber $31.95
#VS50243 victor-
cork $10.99
#17477.14 omix-ADA
Black rubber $13.99
Kind regards
Sent using Tapatalk
1990 Soft Top
