Hey guys I own a 2010 jk with 53000km on it.Lately everytime I start it it hesitates and shakes for a few seconds then idles back to normal.I plugged my obd tool in got nothing.All liquids are nice and level and air filter is new, any ideas where to look?
Check for a leaky injector. Use a fuel pressure gauge to see if the pressure bleeds off quickly after turning the engine off. If your obd tool lets you do an injector balance test run that.
I had to replace the spark plugs in my 2007 at 25K miles to fix a rough idle issue. did it at start up. Occasionally coming to a stop the RPM's would drop to around 300-400 and it would stumble. Not die but engine would shake a bit then come back up to 800.
I used E3 plugs, smoothed it right out and picked up a little low end power.
Never had a problem afterward.
Factory gap was too big on 3 cylinders, 2 were ok, 1 was too small. All were showing signs of slight wear on the electrode.
None of the boots had die-electric grease in them, packed them all before install.
Dealer said the factory plugs are good for 60,000+ miles. It's BS.
