Just bought a 2003 as a salvage project: needed a front suspension including axle, lower control arms, and shocks due to a front end collision (exact circumstances unknown). All done, and successfully inspected, however whenever applying throttle there is a very distinct drone/rumble/vibration/growl that permeates through the entire vehicle.
symptoms:
* occurs ONLY under accel; as soon as you lift the throttle it goes away
* begins almost immediately as the vehicle starts to roll
* the severity of the vibration is proportional to the throttle (worse with more throttle)
vehicle condition:
* overall excellent condition
* new ball joints, shocks, LCAs
* brand new tires (33" BFG mud terrains)
* frame professionally trued and measured
* aligned, with caster set at mid-spec
* 4" lift
* u-joints SEEM ok, but not thoroughly inspected
* rear axle untouched
It seems to me that it's goign to be driveline related, but short of putting a stethoscope on the rear axle while on stands, or pulling the cover, not sure what the usual suspects might be. Hopefully someone on this board can point me in the right direction. Thanks!
symptoms:
vehicle condition:
* 4" lift
