I have a SYE and upper rear adjustable arms
I took a measurement of 14 degrees here
And 17 degrees here
Did I do this correctly? Is 3 degrees enough to make me have violent vibes at speeds under 5 MPH?
Thanks guys!
Knows a couple things...
I can see from your second photo that your pinion angle is too low. The pinion shaft needs to point directly (!) at the CV joint. As below...
Thanks! I just wanted to make sure I was measuring correctly before I went to the trouble of adjusting.
I don't even use an angle finder, your eyeball is good enough to tell when the pinion is pointing at the same angle as the driveshaft is. :)
Going to actually buy my 8.8 (found yet another one) tonight. I have been reading everything i could anout the swap. I think this thread just tired all my info together.
Thanks and good luck
