Wranglers have been know to have problems with corrosion in the guage cluster. It is really easy to pull the dash apart and inspect the connections. There is a thin plastic sheet with the copper wires running through it. Check the connections to the wiring harness and pull the connectors on the guage side too. I found the corrosion on the guage side on mine. A little corrosion is all it takes. I used sand paper to clean it up. Let us know if this helps.
