Haha thanks, they will look even more similar soon.. i'm putting tj flares on
Your jeep will be really tall because those are lift springs for a FSJ. Not to mention it won't ride very well (will be stiff). Depending on what your wanting. If you keep it spring under with stock wagoneer springs and add a 1" body lift and some aftermarket shackles you could easily obtain 4" of lift.what if I was to use these spring from rancho model RS44044? Here is a link
Rancho Part RS44044 - Leaf Spring
I just want to make sure I get the right thing. This is my first jeep build .
So 77 miles away is the closest yard that sells them... and thats at still an astonishing 75 bucks used.... So at thaqt point, i would rather buy new!Stretching your YJ with Wagoneer leafs! If something is unclear just ask. I will add things as needed because I'm sure I missed something.
>>Look closely to make sure that they are 44" long with the center pin being at 21"/23"(offset). On top of the 2" stretch from these leafs, they also provide 2" of lift if you get stock wagoneer leafs. Most people recommend that you use the seven leaf ones. You can find these at most salvage yards. If you want to buy them new you can, but hang on to your wallet! :whistling:
