Hi,
i want to be able to use the A/C in every position of the "mode select control switch".
a guy told me that cutting the upper green cable (the connector on the right upper side on the picture below) and putting in a switch there will make me able to turn the A/C off if i don´t want it.
he also told me that cutting the same cable and putting in a switch between the lower black cable and the green cable will make me able to turn on/off the A/C in every position of the "mode select control switch".
is that right?
thanks for your help.
nicolas-eric
is that right?
nicolas-eric
