I think they are the same. Do you have the side airbags? If so not sure about the airbag or connector compatibility. If you dont and the new seats dont have them should be good to go.
I have side airbags and although the new seats have been stripped of the bags I was hoping to reuse the ones I have in my current 07 seats? So you're saying the connectors might be different? Can anyone confirm! Are the bags interchangeable?I think they are the same. Do you have the side airbags? If so not sure about the airbag or connector compatibility. If you dont and the new seats dont have them should be good to go.
I'm not sure you want to play around with air bags. I'd imagine that you can't put airbags in non airbag seats. The only place that could do that for you if it's possible Is the dealer. Most garages don't want anything to do with airbagsTheHighLow said:I have side airbags and although the new seats have been stripped of the bags I was hoping to reuse the ones I have in my current 07 seats? So you're saying the connectors might be different? Can anyone confirm! Are the bags interchangeable?
my current seats have airbags, so both seats are were built for the airbags, it's just the the junk yard took the actual airbags out of the seats that I want.I'm not sure you want to play around with air bags. I'd imagine that you can't put airbags in non airbag seats. The only place that could do that for you if it's possible Is the dealer. Most garages don't want anything to do with airbags
