Money in hand,
let me know what you have.
Looking for a 4:1 transfer case for my YJ
Look in for sale ads. Someone has one with SYE and Lokar shifter 750 bucks. Its 23 spline input but you can swap it easily.
Too expensive. I found out I can get a new teraflex 4:1 for $850. If I could find a dana 300 I would pick that up to do the np231/300 kit. Anyone got a 300?
I didn't know you could adapt a D300 to a NP231J. How does that work.
Also, I would avoid the Teralow case. They don't like to be ran in high gears (4th & 5th) in low range. That's a deal breaker as far as I'm concerned. If I ever do 4:1, it'll probably be an NVG241OR from a Rubicon.
Or an Atlas. :punk:
DD machine makes a kit to use half of a 231 and a dana 300 to make a doubler that is approximately the same length as a normal 231. Most say it's an inch longer.
I would take a 241 4:1 if I could find one. I've heard that you can burn up the tera's running in low using a high gear as well.
