Yeah, it will be a Warn. Just curious if it was enough and if anyone would upgrade if they had to do it over again.X2.
If you want a winch for those just in case scenarios. Something dependable, solid... which means American made..... Look no further.
The Zeon and other higher priced models are unnecessary. If you just need basic winch... M8000 is it.
I was going to go synthetic, but the price and extra maintenance wasn't worth it for me. If you use it frequently, go right ahead if you can afford it.
That looks like the winch/class 4 receiver combo. Do you have receivers on the front and rear of your Jeep, or just the rear?I have a 12' 2dr JK and use an M8000 with a wireless remote.
8000lbs is plenty for a 2dr. Use a snatch block and you will not need anything larger. And you cannot beat a Warn.
The proof reading is weak in this post.Iv been using kone on my 6000lb JKU for the last 4 years now and it is just verly enough winch for it. For a stockish 2 door I wouldn't see having any issues with it. Especially is you use snach blocks.
It's enough.Yeah, it will be a Warn. Just curious if it was enough and if anyone would upgrade if they had to do it over again.
I have receivers on front and back.That looks like the winch/class 4 receiver combo. Do you have receivers on the front and rear of your Jeep, or just the rear?
