My son (He is 9) and I just installed the winch plate by Hard Rock for the stock JK bumper along with the Warn Zeon 10S. I had used their 9.5ti before but this has to be their best looking winch ever.
The plate installed without a hitch ... they have a great video on the Hard Rock web site. If I was doing it again, I would have six (6) of those funky trim fasteners new from the dealer since it's easiest to drill thru them to get them out and I do want to re install that plastic piece underneath.
They say you can do the job without taking the bumper completely off ... that worked for me just fine. An air ratchet with extensions/universal makes the bumper bolts a lot easier to work with.
The only problem I had was getting the synthetic winch line installed. The loop at the end will not go thru the hole in the drum. They give you a zip tie to attach to the loop and pull it thru ... good luck with that. A super heavy duty zip tie didn't work either.
My son actually figured out the solution before I did. He got a heavy duty boot lace that we wrapped round and round the fair lead and then used the power of the winch to pull the loop thru the hole far enough to insert the key.
The way the plate works is clever. The strength comes from the tow hooks.
We took these pics as soon as we spooled the line by hand. We reloaded it using another vehicle with a tow hook that we pulled up a long incline ... you get a much better wrap that way.
To the guy who gave me the tip and discount code for Zoro ... sorry I forget who that was but thanks very much.
Bill
Bill
