Happened a few days ago, I push the button under the radio to operate the rear wiper (hard top), the wiper arm works, I can hear the washer fluid pump working, but water is not coming out :dunno: there is water in the tank because it the washer fluid reaches the front wipers? What could have gone wrong? Thanks.
check the level in the washer bottle the rear sprayer will quit working at a higher level than the front its a safety thing I guess
You could swap the hose so your front pump operates the rear washer just to confirm pump operation.
If you haven't used the rear in a while, it will take a few seconds to get the fluid back there. It either back flows or evaporates from the hose. I have this happen as well when I haven't used the rear wiper.
