Fuse 12 blew after a carwash on the Red 01 TJ. Crank but no start, no dash gauges, nothing. Towed it home. Found and Replaced the blown fuse. She Started and ran. Looked at C104, it was soaked. And they put the connector right under the hood where water bsoaked it and shorted C104 to ground. Took it apart, slathered in dielectric grease ant taped the connector with electricians tape. Will test it with a hose bto see if it does again. Zoom in and see the water.
Thanks, really good hint. I am going out to rig a plastic cover or diversion. can't really move it. I had a suspect splice in a harness near.
