So I took my muddy jeep to the high powered pressure washer car wash the other day and blasted all the mud off of it. I noticed water had got on the inside and I was mythed. I turned on the AC vents and they were blowing water out the bottom under the passanger. It does it with heat and AC whenever it rains or gets washed. It used to never do that... any ideas?
Jeeper
There's a short hose on the firewall passenger side that gets stuff in it or something... Search around here for water in passenger floorboard and you should find enough info to tell you how to fix it. If it isn't that hose it's probably the cowl drain that's clogged, but it sounds to me more like the little hose thing, since it happens when the heat or air is on... Sorry I can't be more specific, but most days this is as good as I get... :)
