When was your last fluid change? White on the stick obviously isn't good. Did you drop the pan to see what's in it? I found my 32RH(3 speed auto) was extremely finicky until i did a complete fluid flush. Ran smooth after that in all temperatures.
I'm no transmission expert, but that water honestly doesn't look deep enough to me to drown out the transmission. If i recall correctly, there's a vent on the top of the transmission itself, and a breather hole at the top of the bell housing. That water doesn't look nearly deep enough to reach either.
