1 - 14 of 14 Posts
Hey all, I opened the tailgate today and lifted the mat, and saw water where the jack is at. Any idea where it is from?cause i checked the top and around it cant find any clue.
Im not sure if you have hard or soft top or trek. But check here and hopefully this will help.
It likely drips down your zipper on the drivers side, around the tailgate, and onto that tiedown. From there its a straight shot to the jack well.
My bad, forgot to mention that its a Hard Top.
Check the washer fluid tube in the back. That crap would always come off in my 07 JK. I remembered when I ran the fluid it would pop off and get everything wet. Jeep finally addressed that in the Hard Top redesign in 2011 I believe.
I've had the same problem. Thought it was the extra bottle of coolant I had back there for a bit but this makes much more sense. Ill have to check this out and see if I can fix it.
This happens to mine also, a hard top. I just popped out one of the rubber drain plugs and leave it off.
how did they redesign this? I need to re-plug this stupid tube after every time i use it otherwise it pops out the next time.
Discussion Starter #10
Took the plug out so the water would drain. Took a while but freed the jack that was stuck, and cleaned the compartment. just need to use anti-rust on it and grease.
dirt road inspector
Happened to my '07 in a HEAVY rain for the first time in five years. Had to clean it all out and wipe down the jack with light oil. It is a hardtop too.
Maybe the gasket is drying out?
In my 07 JK, the tube just went into the hardtop with no clamp whatsoever, it was a crappy design.
They permanently attached a tube to the hardtop and added this type of twist valve lock that keeps the tubes together. I haven't had any issues with it.
Humm this thread has gotten me to thinking. Maybe I should check my jack for rust. There has been several times that most of the water has drained out of my cooler and I bet a lot of it went into the jack compartment. Then there was the one time that the last half foot or so of my jeep was under water as I was coming out of a creak going up a waterfall. Maybe I should check on the jack in the morn.
1 - 14 of 14 Posts
