Could be either. Look for a void in the seam sealer between the horizontal and vertical cown panels. While you are at it, check the other seams around that area. If there is a void, mask off the area, leaving about 3/16" to 1/4" and squish in a dollop of seam sealer or urethane caulk. Promptly pull the masking tape off and smooth out the edges with your finger. A rubber glove is handy to keep your fingers clean. Touch up with the color of your Jeep.I believe your leak is at the cowl seal not at seam where you put the duct tape.
I think this is something that needs to be done .... if not for the leak now, at least peace of mind.If you have to replace the windshield frame to cowl gasket, search the forum for DREDnots invention to easily pull the windshield frame back into position.
Good Luck, L.M.
Is this the seal you are talking about ???I believe your leak is at the cowl seal not at seam where you put the duct tape.
Thanks for that image ..... it shows me how easy it 'should' be.
Am I missing anything at this point ???????
