1 - 15 of 15 Posts
I found a lot of water in every low spot in my jeep even the little storage in the back. It has not rained and it has been hot, the a/c has not been used. I am sure it is condensation, my Question is how do I fix it. My thoughts on a solution, Pull the rug and add undercoating or rhino lining, or would popping open some of the drain plugs do the trick?
i'm back
:thumb: all of my drain plug stay removed...
Pulling the drain plugs is all fine and everything, but where the hell is the water coming from? That would be my concern.
I am 100% sure the water is just condensation form the hot days and cool nights. I saw the plug under the storage, that spot took 2 towels b4 it stopped dripping. Ill have to look in to lining when I get back to the states, Thanks everyone!
Good lord. I have never heard of that much condensation inside a vehicle.
Me either, if it was condensation then many of us would be having the same problem. That water is coming from somewhere and I'm sure condensation isn't it. :popcorn:
Mine was leaking around the freedom top panels.I only had water in the front passenger floor and when I took it back they actually had a ROOF SPECIALIST,said the factory always has a hard time installing the gaskets correctly.It hasnt leaked since.If you run rubber floormats it will keep the moisture in.Hope this helps!
i'm back
the carpet under my seats gets wet from time to time too.. it's not from a leaky top... probably just because i run my air conditioner on kill... :whistling:
Discussion Starter · #12 ·
The wife may be leaving the window cracked? Like I said it has not been raining and its been hot as balls out unless my little town has a water dumping bandit then I don't know what it would be.
Do you have a hardtop? If so check the seals on both sides of the glass near the bottom. The right side of mine was worn out allowing a drizzle of water to go down. I put some weather stripping in its place and it stopped. It is where the glass seals against the tail gate on each side of the back bar.
1 - 15 of 15 Posts
