I am new here and finally decided to make an account. So with that said, hello all!
I have a weird clacking noise that sounds like it is occurring near the rear driver's side. It only occurs at low speeds (3-30 mph?). it goes away when turning but returns shortly. It goes away when the brake is applied but comes back once depressed. The noise does speed up as i go faster, however i never notice it once i get up to highway speeds.
Thanks
First thing to check is if you have a large rock stuck between the treads or some metal that has lodged in the treads.
Commercial Member
Sounds like a driveshaft issue, probably rear since it is under load almost always, unless your driving around in 4wd, which I doubt...
The video is unclear, but could also be the infamous ticking if it is happening when idle as well.
